Displays various BOOTP Relay configuration details.
| ipv4 | Specifies unconfiguring the DHCPv4 BOOTP Relay service (default). |
| ipv6 | Specifies unconfiguring the DHCPv6 BOOTP Relay service. |
| vlan | Unconfigures BOOTP relay for a specified VLAN. |
| vlan_name | Specifies the VLAN name. |
| include-secondary | Removes the include-secondary configuration for the specified VLAN. |
Use this command to display various bootprelay configuration details.
The following command displays IPv4 bootprelay statistics:
# show bootprelay configuration ipv4
DHCPv4 BOOTP Relay : Enabled on virtual router "VR-Default"
Include Secondary : Enabled (parallel)
BOOTP Relay Servers :
DHCP Relay Agent Information Option: Enabled
DHCP Relay Agent Information Check : Disabled
DHCP Relay Agent Information Policy: Replace
VLAN DHCPv4 BOOTP Relay
VLAN "Default":
Include Secondary : Enabled (sequential)
BOOTP Relay Servers : 192.168.1.1
VLAN "v1":
BOOTP Relay Servers : 10.1.1.1
This command was first available in ExtremeXOS 15.4.
